Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Does Not Turn On
Battery drain out or Power button does not work
Faulty Batteries
If the batteries in the device wear out due to excessive use, they must be replaced with new batteries.
Battery Socket is Broken
If the battery socket is broken due to regular wear or mishap, the battery socket needs to be replaced.
Button Unresponsive
If the power switch is activated but does not work, it must be replaced.
Button Gets Stuck
If the power button becomes lodged or stuck in the device, it should be taken apart and readjusted or replaced.
Music Button Issues
Music button becoming unresponsive or getting stuck
Button Unresponsive
If the button is unresponsive, there might be a battery issue, otherwise, the button itself needs to be replaced.
Button Gets Stuck
If the music button becomes lodged or hard to press it may be placed in the incorrect position. It may need to be replaced or readjusted.
Lights Do Not Turn On
Certain LED lights on the device broke and needs replacement
LED’s Stop Working
If the LEDs are unresponsive, there might be a battery issue, otherwise, the LEDs itself need to be replaced.
Speakers Stop Working
Music from device speakers is not loud or is distorted
No Sound From Speakers
If there are no sounds coming from the device, there might be a battery issue, otherwise, the speakers need to be replaced.
Music Is Distorted
If the audio becomes distorted or choppy, the speaker may be faulty and require a replacement.
Volume Too Low
If the volume of the music is lower than the default setting, the batteries may be low, otherwise the speakers are faulty and must be replaced.
The Ring Handle Breaks Off
Handle and the attached rings get damaged
Handle Breaks
If the handle shatters, breaks, or is damaged in any way it will need to be replaced.
5 Comments
The music is not playing the full songs. More like intro to every song once it's activated
ddivex Wu - Reply
I have the same issue. It'll just play the same 5ish notes over and over, none of the other functions work. It goes away if I turn it off and on a bunch of times, but the issue comes back not long after.
Josh Kay -
It's playing the keys by itself? Is it faulty or ghosts. I'm freaking out it's never done it before. It's on just the piano setting and no one or anything is by it that could make it play the keys. They also seem to be different keys. 😅😅😅
Sydney Jacobsen - Reply
When I try to change the languages it is only doing French and English and when I want to go back to a different language it just stays French and doesn't reset until going to turn it off and turn it back on
Jasmyne Arroyo - Reply
2 yellow wires inside have come loose, where do they attach to?
Pete Cavello - Reply
