Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Automatically Shuts Off
During normal operation your vacuum shuts off without warning. It may not turn back on until after a minute or so.
Not properly plugged in
Ensure that the vacuum is properly plugged all the way in and that the plug is not being pulled out out of the wall by using the vacuum. If you suspect the outlet is faulty, try plugging a working lamp into the outlet and seeing if it illuminates.
Overheating motor causing an automatic shutoff
If a vacuum motor overheats due to poor airflow, the vacuum will automatically shut off. This is most commonly caused by an air passage that is plugged by hair or dirt. Refer to the leaky hose guide to remove the hose, then inspect for hair or dirt clogs.
Sudden Loss of Suction
There is no longer suction coming from the vacuum cleaner, preventing it from cleaning floors.
The Bag Is Full
If a vacuum has a full bag, the vacuum will sound like it is working but be unable to suck up additional dirt. If the bag is full, try emptying it and see if that restores suction power.
The Accessory Hose Is Clogged
Vacuum hoses can become clogged by large particles over time. Try following hose replacement guide and inspecting if you have suction where vacuum hose connects. If you have suction where the hose connects but not after the hose, your hose probably has a clog in it.
The Vacuum Isn't Airtight
If there is a hole in your vacuum lines somewhere, air will be sucked in there and not from the vacuum hose. Try feeling around the vacuum and see if there suction somewhere other than the hose. Often this will happen around areas like where the bag attaches or at the hose connector.
Burning Smell Coming from Device
Any sort of burning smell is coming from the device.
You're Plugged Into a Faulty Outlet
This can be checked by plugging into a different outlet. Having the device plugged into a faulty outlet can cause the plug to heat up and possibly burn plastic.
The Electric Motor is Overheating
The vacuum could possibly smoke if the electric motor is overheating. This is remedied by emptying out the bag and clearing any debris that would block airflow to the motor.
The Motor is Being Overworked
Overheating due to overwork would cause mostly the plug is not the vacuum to heat up. If you have been vacuuming for a long period of time, take a rest, so that the vacuum can cool down.
Hair is Caught on the Rotor
If hair is sucked up into the vacuum and gets stuck on the rotor of the motor, the motor could generate enough friction to create heat and burn the hair. Turn off the vacuum, empty the bag, and feel around for ay hair that would be stuck to the motor.
Dust Leaking Out of the Device
Your vacuum is blowing out dust.
Dust Container Full
A full container can cause a loss of suction and not allow more dust to be stored in the container. Try emptying out the dust container.
Dirty Filters
Check both the primary air filter (blue colored in the dust cup) and the HEPA filter for any dust clogging. Clogged filters force air out of the device, bringing dust with it. Try following the primary air filter and the hepa filter cleaning/replacement guides to see if they stop the dust leak.
Device Not Turning On
Your device is not receiving power.
Device is not plugged in
The devices cord has a limited length and can be pulled out of the outlet. Check to see if the plug has been pulled and plug it back in. The device should now turn on.
May have blown a fuse
Check to see if the outlet is working if other electronics are not receiving a charge from the outlet, then the fuse is blown. If this is the case, go to the fuse box and turn the fuse, for which outlet the device is plugged into, off and then back on. This resets the fuse and now the device should turn on.
52 Comments
I have cleaned out the ‘bag” and the filter, my hoover windtunnel is now blowing out instead of picking up - sucking up dirt - just blowing it away? Any ideas??
Colleen Leigh - Reply
I picked up something the carpet that seems to have stuck inside the vacuum. I taken bottom off an it's not in there is there somewhere else something can get stuck in? Its making loud noise like something would be caught on a spinning part
deborah grice - Reply
Probably something stuck in the nose. Take the nose off an use a broom handle to push the mess out.
gvburnett -
A member of my family tried to vacuum up some water and now it won’t work. What can we do?
cerickson62 - Reply
Id start with: slap your family member across the back of the head, then throw the vacuum out and buy another. Lastly, don't allow the family member to touch new vacuum and you should be good as gold
Sarah Gibson -
