Table of Contents
Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Won’t Turn On
The screen doesn’t turn on and there is no sound coming out of the speakers.
Power Cord is Unplugged
Though it may seem obvious, make sure that the power cable is fully plugged into the device and the electrical socket. If it still doesn't turn on, the cable may be damaged.
Dead Batteries
The batteries may need to be replaced. Make sure you don’t mix old and new batteries! Also be sure to put the batteries in the configuration shown in the manual. Note that this boombox doesn't use the batteries when the power cord is plugged in.
Power Switch is Off
It is possible that the machine is switched off. Check the switch located on the right side of the device labeled “Power” and switch it to the “on” position.
Damaged Motherboard
The motherboard that controls the device may be damaged. See the motherboard replacement guide.
Damaged On/Off Switch
The On/Off switch may not be connected to the motherboard. Follow the steps in the motherboard replacement guide to access the motherboard.
Radio Lacks Reception
When you try to use the radio, static or no sound is heard.
Radio is Out of Tune
Your current location may not have reception. Try moving to a different location for better reception.
The radio may be tuned to a station that doesn’t exist. Try switching to a different station by rotating the radio tuner on the right side of the device.
Broken Antenna
Your device’s antenna may be broken. To replace the antenna refer to the antenna replacement guide.
No Sound/Distorted Sound from Speakers
Static, garbled sound, or no sound is coming from the speakers.
Volume is Too Low
The radio may be working fine, but the volume may be set too low for you to hear your favorite station. Turn the the volume dial on the left side counterclockwise to increase the volume.
Earphones are Plugged In
Your earphones may be plugged into the device, causing the sound to be played from the earphones. Make sure to remove the earphones from the audio jack.
Damaged CD
You may have a faulty CD. Try playing another CD to see if the problem persists.
Wrong CD Format
Check if your CD is in CD, CD-R, or CD-RW format. Other formats will not play on this device.
Broken Speakers
Your device’s speakers may be broken. To replace the speaker refer to the speaker replacement guide.
Speaker Has Water Damage
The speakers may have water damage or other minor damage that render them unusable. To replace the speaker, refer to the speaker replacement guide.
LCD Display is Unreadable
There are graphical glitches. Certain parts of the display fail to turn on or are ghostlike.
Batteries are Dead
The batteries may be too low to power the display. Refer to the battery replacement guide.
Bad Connection to Switchboard
This could indicate a bad connection to the switchboard. You may need to clean the contact points on the board or just replace the board. Refer to the switchboard replacement guide.
Buttons aren’t Working
Nothing happens when you press the buttons on the front panel.
Jammed Buttons
The switches inside the buttons may be misaligned, need to be cleaned, or are broken. Refer to the switchboard replacement guide to access or replace the buttons.
Broken Buttons
If the buttons are physically damaged, replace the buttons using the switchboard replacement guide.
Kristin Yoshioka
984 Reputation
9 Guides authored
UC Davis, Team 1-5, Oliver Fall 2016 Member of UC Davis, Team 1-5, Oliver Fall 2016
UCD-OLIVER-F16S1G5
5 Members
11 Guides authored
4 Comments
LCD light is on and device is unplugged with no batteries. Won't power on when plugged in. Resolution: leave unplugged until LCD fades. Plug in.
demurphey - Reply
Speakers work about half the time and it's only one that plays any sound. Only about a month old. I bought for my barn and it's a $30 piece of junk. I wont buy insignia products if I had to…
frankiebilbrey - Reply
The cd tray is unresponsive
Jason Galvin - Reply
I got this cd player recently and tray is somehow stupid, and by that I mean the LCD screen will not show the cd tray is open!
Jason Galvin -
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 43
All Time: 4,808
