Magic Bullet NutriBullet Blades Will Not Turn
Arielle Sampson and 2 contributors
Last updated on
Does your Magic Bullet NutriBullet no longer spin and blend? Does the motor make noise but the blades refuse to turn? NutriBullet blenders are susceptible to a range of problems that could cause the blades to not turn, many of which are simple to fix. Check the following possible causes to identify and solve the problems.
If your NutriBullet is not making any noise and shows no signs of life, see the NutriBullet Won’t Turn On problem page, instead.
Causes
Magic Bullet, the maker of the NutriBullet, recommends that users do not blend for longer than one minute at a time. Prolonged use of the blender can cause the motors to wear out quickly, which can cause the blades to stop spinning. Unplug the NutriBullet blender and let it rest for a few minutes. Then, plug the blender back in and try to use it, again, making sure not to leave the blender running for more than one minute at a time.
2
If the NutriBullet’s motor becomes overheated, it may stop working. If the blades do not turn and you notice a burning smell, unplug the power base from the wall socket and allow the base to cool for an hour. The powerbase should reset once the unit is unplugged, and resting the motor will prevent further overheating and damage. After an hour of rest, plug the NutriBullet back into the wall socket and try to use it again, being careful to not leave the blender running for more than one minute at a time.
If the Magic Bullet NutriBullet has been used for extended, non-pulsed use, two electrical components might have failed that can cause the blender to not spin. In both cases, there was probably a smell of hot metal or burning electrical components at the time of failure. One component is a heat sensor which fails permanently if the motor coils heat above 150 degrees Celsius (302 degrees Fahrenheit). The other component is a set of carbon brushes that conduct electricity to the commutator segment of the blender’s motor. Diagnosis of these electrical problems will require the disassembly of the unit and will require an electric multimeter to assess conductivity. Follow this Magic Bullet NutriBullet Activator replacement guide to disassemble the unit.
3
The white activators located on the top of the NutriBullet’s power base are required for the machine to begin blending. If the blender’s blades fail to turn when the cup is in the power base, the blender’s activators could be stuck. Use this NutriBullet activator replacement guide to fix or replace the blender’s activators.
View statistics:
Past 24 Hours:
20
Past 7 Days:
100
Past 30 Days:
588
All Time:
23,194
