Table of Contents
Page Stub
This wiki page is a stub. Help us improve this page by adding information to it!
Flash Not Working
  • The solution to the flash not working may be as simple as resetting your camera which can be found using the Reset Guide.
  • If resetting the camera does not work you may need to replace the flash in your camera using the Disassembling the Flash Guide.
Camera Is Unresponsive
  • This is an easy fix that could be solved by verifying the camera battery is charged.
  • If your battery is charged and still does not work you may try pressing the reset button using instructions found in the Reset Guide or try replacing the battery using the Removing the Battery Guide.
Pictures Appear Blurry
LCD Screen Not Working
  • The first solution is to make sure the battery is fully charged.
* If the battery won't charge, it may need to be replaced, it can be done following the Removing the Battery Guide.
Broken Lens
<<Back to the Device Page
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 796
