Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Wheel Randomly Veers
The steering on the car randomly veers.
Wheel sensitivity needs to be adjusted
The device has 2 different sensitivity modes:
- Normal sensitivity, which is the default mode
- High sensitivity, this mode has to be selected manually
To enter the sensitive mode, press and release together:
the Engine start + the 2 Up & Down paddle shifters.
The following page has the diagram and labels:
https://www.manualslib.com/manual/111459...
Try reinstalling wheel to console
Installing the wheel:
1. Press the XBOX switch that is on the back of the wheel.
2. Plug the wheel’s USB connector into one of your XBOX's USB ports.
3. The wheel will be detected under the name FGT Rumble 3-in-1 or Ferrari GT Experience.
My Pedal Set Is Not Functioning Correctly
"Does not function when I play the game."
Connecting pedal to the wheel
Be sure to connect the pedal set to the wheel before connecting the wheel's USB to your XBOX.
- Reconfigure the wheel in the controller options. Always make sure that the wheel is correctly connected.
The Pedal Broken
"You accidently broke the pedal and now you have to change it out"
Replacing the broken pedal
-First step is to order the parts from: https://www.partsit.com/product/thrustma...
-Once you receive the part we can start dissembling the device.
-Follow the steps in the guide to replace either gas or break pedal
Wheel and Pedal Connection Port
"The pedals stopped responding."
Damaged wheel and pedal port
The port for which the pedals connects to the wheel is damaged . We'll have to open up the device to change this.
Wheel and Pedal Connection Port Replacement
USB Port Damaged
"The USB cable got damaged and now it will not plug into your XBOX."
Replacing the USB cord
-Follow this guide to replace your USB cable
Motherboard Damaged
"The Motherboard got damaged and now the device will not function correctly."
Replacing the Motherboard
-Follow this guide to replace your Motherboard
73 Comments
I can't get the steering wheel to turn but the buttons and pedals work how can I did this on a xbox one?
Jodi - Reply
Were you able to fix your problem. The same thing just happened to my son's wheel.
Cherry C. -
We are having the same issue. Would be good to know if anyone has resolved this
Sameer Alam -
My steering panels work but won't turn any help..and how can u play gta with it
Ayden Young -
Unplug the steering wheel from xbox then unplug the pedals from steerining wheel plu them back in then plug the steering wheel into the xbox
Shane Snyder -
