Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Battery life of RC truck is short
Battery needs to be charged longer
Ensure that the battery has been charged properly for the full four to six hours recommended by the manufacturer before using the truck. If you don't, the truck will not last as long as expected.
Battery needs to be replaced
If you charged your battery properly and it still seems that the time of usage between charging periods is too short (i.e. less than 10-15 minutes), consider replacing your battery.
Range of RC controller is limited
The RC truck stops responding to the controller after it gets a short distance away from the user.
Controller is low on battery
The battery of the controller may be low on charge. Try replacing the 9V battery of the controller.
Antenna of either truck or controller is damaged
There's a chance that the antennae (the wires sticking out of the controller and truck that transmit and receive the your input) are broken. If one or both of these is broken, the truck will not respond. Check your antennae, and consider replacing them.
RC truck is unresponsive
The RC truck does not respond to the controller at all.
Out of charge
First, try recharging the battery, ensuring that the charger is properly connected. If this doesn't help, try replacing the 9V battery of the controller.
Battery is broken
Check to see that the 9V battery in the controller and the 9.6V rechargeable battery in the truck both have enough charge and are plugged in properly. If that's the case, then one or both of the batteries might be malfunctioning; consider replacing either the truck's battery or the controller's battery.
Antenna of either the truck or controller is broken
RC truck has problems turning or driving in a straight line
The truck isn't turning well or is unable to drive in a straight line.
Wheels are obstructed
The truck may be having problems turning because of small obstructions in the wheel, like mud, gum, or sediment. Check the area around the wheels and remove any obstructions you see.
Wheels are out of alignment
The front wheels often come out of proper alignment during use, and a quick fix conveniently is built into the truck itself. A wheel alignment adjustment knob is located between the front wheels, in front of the battery pack. Turn the knob until the front wheels are parallel with the rear ones.
Suspension is malfunctioning
If the knob doesn't solve the problem, check the suspension (the springs and rods that connect the wheels to the chassis of the truck). If they look uneven, then try replacing either the front wheel suspension or the rear wheel suspension.
Truck is low on charge
If the truck is having problems turning, there is a chance that the battery is running low. Try recharging the battery and, if the problem is persistent along with a short run time, try replacing the battery.
Truck tires are damaged
The turning problems the truck has might be caused by damaged tires, either because the treads can no longer get traction or because the wheels are misshapen. Check the treads and rims for visible damage and consider replacing your wheels.
Control servos are malfunctioning
The control servos are the part of the truck that reads your directions from the controller turns the front wheels. With the truck and controller on, check to see if the wheels turn accordingly as you turn the knob on the controller. If not, a replacement of the control servo is your best bet.
RC truck is slow
The RC truck is unable to reach it's top speed and/or is slow to accelerate.
Truck is out of range
Make sure you are close to the truck in order for the transmitter to receive radio signal from the controller; the closer it is, the better it will receive your signal. Also make sure to be in a location with little to no radio interference from other devices.
If the truck seems to be slow, there is a chance that the battery is running low. Try recharging your battery and, if the problem is persistent along with a short run time, try replacing the battery.
The truck may be moving slowly because of small obstructions of the wheel such as mud, gum, or sediment. Check the area in and around the wheels and remove any obstructions you see.
If the front tires are turned even while the controller's off, the front wheels are out of alignment. The truck wheel alignment may be adjusted under the truck. The knob to adjust the steering wheel is located forward of the battery compartment. Turn the knob until the wheels all the wheels are parallel.
The truck may be going slow because of damage to the tires. Check the tires for visible damage and consider replacing your tires.
Motor of RC truck is damaged
If you checked all of the options above and your monster truck is still unable to go near the 25 MPH speed advertised by the manufacturer, the motor of the truck might be having problems. Try replacing the motor.
2 Comments
“Traxxas is proud to be the Official and Exclusive Hobby Class Radio Control Vehicle of Monster Jam Europe,” said Traxxas President Mike Jenkins. “We’re bringing our full program to supercharge the excitement for European Monster Jam audiences. Each event will feature high-flying, action packed radio control stunt demos, a full product showcase, and our popular Try-Me Track where show attendees can test their own skills on our specially prepared track.”
https://babyishcare.com/radio-control-mo...
Beth Bishop - Reply
I just got a hosim X07 and straight out the box it won't power on the ESC fan will come on but that's it anyone have any ideas I think it may be the ESC but I'm not sure
Jason Sargent - Reply
