CMOS / BIOS Battery
2 Answers 1 Score |
screen won't light up |
1 Answer 0 Score |
Does this have an M.2 SSD expansion slot? |
1 Answer 0 Score |
Replacement for DC POWER JACK HARNESS PLUG IN CABLE FOR LENOVO |
1 Answer 1 Score |
Screen rotates when I don't want it to |
Documents
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
3259, 6272
Processor
Premiere performance and ultraportability; two spindles
Available processors are:
Intel® Core™ Processor i3-2350M with dual-core (2.30GHz), 3MB Cache
DDR3 memory controller (up to 1333MHz), HT technology
Intel® Core i5 Processor i5-2450M with dual-core (2.50GHz), 3MB Cache
DDR3 memory controller (up to 1333MHz), Intel Turbo Boost 2.0 (3.10GHz), HT technology
Intel® Core™ Processor i5-3210M with dual-core (2.50GHz), 3MB Cache
DDR3 memory controller (up to 1600MHz), Intel Turbo Boost 2.0 (3.10GHz), HT technology
Intel® Core i7 Processor i7-3612QM with quad-core (2.10GHz), 6MB Cache
Intel® Celeron® Processor B815 (1.60 GHz), 2M Cache
DDR3 memory controller (up to 1066/1333)
Intel® Pentium® Processor B960 (2.20 GHz), 2M Cache
Memory
PC3-12800 Non-Parity (NP) Double Data Rate Three (DDR3) Technology
Dual-channel capable
Two 204-pin SO-DIMM sockets
The use of 1066 MHz SO DIMM memory is recommended for this system.
2GB, 4GB or 8 GB memory
Supports up to 8GB maximum memory
Display
15.6" HD LED-backlight display, Anti Glare
15.6" HD LED-backlight display, VibrantView
Graphic Controller
Video chipsets:
Intel HD Graphics
Hard drive features
320 GB, 5400rpm, 9.5mm high, SATA HDD
320 GB, 7200rpm, 9.5mm high, SATA HDD
500 GB, 5400rpm, 9.5mm high, SATA HDD
500 GB, 7200rpm, 9.5mm high, SATA HDD
750 GB, 5400rpm, 9.5mm high, SATA HDD
