No Power - not surge related
Used this receiver one day, the next it was dead. There was no power outage or surge. There is no display and not responding to the remote or switch. Checked all the power components and they appear to be okay. Getting power to the unit, but not going through the transformer on the power supply board. Relay is not clicking, not getting the signal to turn on. I tried to trace this problem, but I do not have the service manual for this unit and did not see it anywhere on the internet. Checked your site and you do not have it, but thought maybe you can help look for the problems. Any suggestions on what to check next?
18 Comments
Just to make sure, you did check your fuse?
by oldturkey03
How do you check and/or replace fuse? Where is it located?
by ricworkdoc
I have the same problem.no secondary DC voltage ..fuses ok and omron relay is also ok but no dis play
please give me advice
by robwinn
If We recently learned after a lot of research and trial and error that the solution was in front of me and not on Google all you have to do is enter the back up system and reboot it pressing random combinations until I found the right one unfortunately I cannot provide that combination as I do not remember it. Just try messing with the buttons and see what happens. I hope this helps and of I can I'll try and figure out the combination
by Harley Thomas
Likewise…I had no luck until I tried LeoDJ's suggestion. Unfortunately fir me it only stays on for about 3sec and then shuts off again. Any ideas what I need to do next? Thanks! Adam
by Adam Snitchler
Show 13 more comments
