dvd wont play in e drive
i can't play dvds
You may just need the drivers. Install vlc and you should be all set. http://www.videolan.org/vlc/index.html
As you didn’t provide more info, I would recommend you to:
a. check if your disc drive, or if the DVD disc is damaged and repair the drive/disc if necessary;
b. check if the DVD is from another area, namely if there is region code protection on it; if it is, change the region code of your DVD player
c. try another DVD player like VLC;
d. convert the DVD to digital with Handbrake, MakeMKV, WinX DVD Ripper, etc.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 337
