The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
115 Questions View all
Question Closed
WIFI was flakey then stopped working
My Samsung Note 10.1 (2014 edition) tablet had worked for about a year then the WIFI started disconnecting and reconnecting. It progressively got worse until it would intermittently connect for a minute or 2 before the WIFI died completely. I tried several different access points and had the same issue. Tried turning WIFI off/on turning airport mode on/off and rebooting the device. Still had the problem so I did a factory data reset but that didn't resolve the issue either. At first I was thinking it was a software issue but now wonder if it is hardware related and if the problem is somewhat common?
Add a comment
1 Answer
Hi Erik,
I would role out the software issue since the factory reset didnt help you and because the problem appear progressively. It looks more like a faulty part that was dying.
I think it maybe your baseband or Wifi IC chips. Or one of the components that are related to thoses chips.
Aside if have High soldering skills and good equipement (mostly a good microscope), I dont recommend that you try to repair this yourself.
You can ask Jessa from iPad Rehab if you live in the US. But I not even sure that she we be able to help you since it's a somewhat uncommon issue.
Max One
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 126
