after windows 10 computer will not recognize the dvd drive.
i loaded windows 10 and the dvd drive which worked flawlessly on 8 no longer works.
It does not appear when I look for it. It will not even open unless I use a wire to release it manually. can't be a hardware problem.
Add a comment
1 Answer
Chosen Solution
Jerry, check the attached link, I think it may help diagnose and enable you top fix your Lenovo DVD issue. I believe it list 5 methods to solve issue.
Check the attached link,instruction and guides, Good luck
https://support.lenovo.com/ca/en/documen...
Score 2
Add a comment
Add your answer
jerry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 130
