Security Screw Driver 4PS SCUF
Hello, Been looking to open my scuf controller as the charging port is broken.
I cant seem to find the right security driver for opening it up.
Any help would be great thanks.
Update (10/21/2016)
Took these pictures to see if this would further point me in the right direction!
thanks
Score 2
8 Comments
hi, how did you open it?? i need to open it too lol
by
Why is this marked solved. It is not solved. The guy is trying to find out what kind of screw it is so he can take it out himself. The question wasn't, How can I destroy this screw and ruin my warranty while trying to get inside of this controller. So did Scuf have this screw invented specifically for them? Why does no one seem to know what kind of screw that is?
by
thanks for the reply!
Yeah scuf invented the screw currently you cant buy the driver on the market, still looking but cant get it...
by
Guys I see this is an old thread and without arguing bit type there's a very simple answer, just take a Dremel or something similar and cut out a slot to make it a flat head screw. I ended up fixing my paddle which is why I came here with alcohol and spray air, but if needed this was how I was going to remove the mystery security screw. I have a good sized set of security bits and apparently this ones pretty uncommon.
by
We are looking for an option for people who don't want to accidentally destroying their product by melting or sawing their product.
I mean if it comes to it I will probably do that cause &&^& the $89 deductible but I want to find a screw for it first.
by
Show 3 more comments
Add a comment
Chosen Solution
Gosh, this was a pain to find! So here it is what looks like the appropriate bit…
Part documentation
https://uk.c.misumi-ec.com/book/SAI1_SEA...
Part
https://uk.misumi-ec.com/vona2/detail/22...
I’m not absolutely certain on the required size of the 2 available sizes for the bit. My guess is part number SF3B.
Corresponding screw
It looks like you can source the part in single units but it’s quite a pricey exercise as its about EUR 40 shipped, at east to where I live.
GGs
Score 7
10 Comments:
Holy $@$* you did it...
Now how do we make this the correct answer?
by
wow, 35 pound a bit.
by
How did you find that man?
by
Has anyone bought this and confirmed its the SF3B?
by
Nice find, from looking at your results, it seems the screw is a
System 5 SF010206
System 5 M2
dk of 4.5
Nominal of Thread (M) 2
Length L (mm) 6
Pitch (mm) 4.5
so the bit that will remove it is a SF2B bit and from what I can find it cost $37.91.
Screw: https://us.misumi-ec.com/vona2/detail/22...
Bit: https://us.misumi-ec.com/vona2/detail/22...
by
Show 5 more comments
Add a comment
Here's a repair video on it, but the guy modified the screw and it does focus well enough to see what type it is. Post a picture of it would help us to find out what it is:
https://www.youtube.com/watch?v=AHPRyOel...
My research says it's an E5 torx like this:
http://www.kmart.com/gearwrench-1-4inch-...
Score 3
10 Comments:
I added the pictures i took and a small video, thanks for the reply!
by
Yep, looks like a E5 Torx
by
Ill order one and see what happens :)
It does look a bit big for the hole tho? wouldnt you agree?
Again thanks for the reply.
by
Those look like star and game bits.
by
It does look right for the game bit part except it only has 5 bits on the screw instead of 6 like the gamebit driver
by
Add a comment
Based on this video, it appears the fixer is using a Spanner bit. Unsure of the size.
You can find three of our Spanner bits (in 4mm for your driver) here: iFixit Precision 4 mm Screwdriver Bit
iFixit Precision 4 mm Screwdriver Bit Image
Product
$2.99
Score 2
1 Comment:
I found the 6 and 8 to be the most useful
by
Add a comment
I found a company that will sell you the bit along with the screws, supposedly you only need to purchase a single screw. The company is a Japanese company called Saima, the bit is one of their "System 5" bits. There are two sizes, and the part numbers are SF2B and SF3B. I emailed "info@saima.co.jp" to place my order and spoke with a man named Yoshinori Kase who helped me out. Unfortunately I had reached out to them with my business email address, and when they found out I was a firearms dealer, they then refused the sale. However, this shouldn't be an issue for the rest of you. Also, those claiming that 6 lobe bits and any other product they found is correct are either mistaken or lying.
Score 2
7 Comments:
I assure all of you that this is the definitive answer to this question at the time of this post. According to Yoshi, they will sell you a single screw and bit together, but not the bit alone. I have no idea what shipping would cost as I never got that far before they found out I was a firearms dealer.
by
I have ordered the SF2B bit from Misumi. It was pretty painless outside of the cost. I’m waiting for it to arrive.
by
@livefast9986 The reason I attempted to order directly from Saima (the manufacturer) instead of going through Misumi is because they don't even list the United States as an option when registering an account and, as far as I can tell, you must create an account to even add items to the cart or request a quote. I assume that you either live outside of the US or contacted them via email?
by
Nope. I literally just went to the website, made an account, and ordered it through their online website. I live in the US. It took less than 3 minutes for the order.
by
My SF2B bit came in and it doesn’t fit. It’s either the wrong size or the shaft is too big to fit over the screw and is hitting the sidewalls.
https://imgur.com/gallery/GZupQyv
Anyone have advice?
by
Show 2 more comments
Add a comment
I’d like to say the answer is https://www.reddit.com/r/scufgaming_fix/... I hope it helps anyone looking for this screwdriver for Scufgaming controllers.
Score 1
Add a comment
Add your answer
cocothevillageidiot will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 119
All Time: 59,766
