The Samsung Galaxy J2 is an Android smartphone that was released in November of 2016.
107 Questions View all
Hi. I dropped my Samsung Galaxy J2 and the screen turned black
Hi. I dropped my Samsung Galaxy J2 on its back and the screen turned black. I can hear the sound when i restart my phone, but the screen is always black. What should i do ? I remove the battery then put it back again but still don't work. Please help i'm desperate !
Score 13
10 Comments
i also have the same problem even worse my phone got hot
by
Plasae help me j200h phone dropid after display problem
by
My samsung j2 mobile screen sometimes black . How i can stop this problem?
by
Replace the LCD....it's 1000 solution for u
by
My samsong galagsy j2 have black vapour on the top screen, the vapour gradually flotting down the screen and within 24 hours the phone screen was totally black. What could be the problem? Is it that the phone screen as expired or it is virors problem? Please I need help.
by
Show 5 more comments
Add a comment
Chosen Solution
Hi,
I believe that there could be 2 main reasons why your phone's screen is black:
1.After the drop your LCD connector disconnected.
2.Your LCD broke from the impact.
In any of these cases you would have to remove the screen and check the connector, if that's not the case you will need to replace the display.
Score 7
3 Comments:
how do you remove the screen
by
Yeah..Exactly...How do I remove the screen to cheak if the LCD connector is disconnected or my LCD broke ???
by
I did many things like removing the battery, charging the phone over and over to see if the phone is working or not but it still do the same so what sign will it tell to tell if the LCD is broken and how can I also find out that the LCD connector is disconnected? and also what is LCD?
by
Add a comment
When you remove the battery cover look on the back of the phone. There should be a small compartment on the left side just below the camera. Pop the cover off and it will reveal the connector for the LCD screen. Check to make sure the connector is plugged in. To check to see if your screen is the problem, use a friends phone and plug their screen directly into your phone. If their screen lights up and works off of your phone's motherboard then you have a bad screen.
Score 1
Add a comment
Hi
So heres what I think have might happen ed
1.the back light died.
2.the connection to the lcd might have come loss
I hope this helps out
Score 1
Add a comment
then you remove ur phone battery and hold power key and volume up bottom and then fix ur battery then rest ur phone
Add a comment
Display change price
Add a comment
Add your answer
Genevieve will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 104
All Time: 11,636
