Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Wi-Fi Signal very bad
Hello all!
A few weeks back a customer came in with he's iphone 5S and said the Wi-Fi Signal was acting weird. He also said that he has to be very close to the router in order to get a good signal. So i did some testing and as soon as i walked away from the router the signal droppet to 2 Bars. After walking about 3-4 Meters away from the router the Wi-Fi Signal was completely gone.
So i went ahead and changed the Wi-Fi antenna. This didnt help very much So after i tried the following:
1. Restored and updated the phone
2. Changed the Wi-Fi Antenna again (in case the first one was broken)
3. Did a software rollback to IOS 9
4. Didnt help so i went ahead and restored and updated the phone in itunes.
All this and still the same result. Bad Wi-Fi signal. Anyone have any ideas?
Add a comment
Chosen Solution
@captaintech , Svein, could be a problem with your phone’s Wi-Fi IC failing, Check the link below, may help solve your issue. Good luck.
http://blog.brokenlcds.com/iphone-5-blue...
Score 3
2 Comments:
Thank you! It was very helpful but my customer didnt want to bother with it anymore after changing the charging port and flashing the firmware didnt work.
by
Svein Sivertsen , Thanks for replying back, have a good day.
by
Add a comment
I've seen this happen before in a 5s and it was slightly water damaged. Is there any sign of water damage? If not, try the charge port too. This shouldn't have any bearing technically on the Wifi signal, but I have seen this fix the Wifi signal before. If that doesnt help, more than likely you have a board level issue somewhere. There are several reputable eBay companies that do board level diagnostics and repair. I have used a company out of NY who does excellent work.
2 Comments:
Ill try that and let you know how it goes. Thanks for your answer :)
by
Changed the charging port with no luck. i've also flashed its firmware and tried updating again. The customer was not interested in trying anymore.
by
Add a comment
Add your answer
Total Repairs AS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,180
