Why is my shaver not working as efficiently as it did previously?
Overtime my razor has continuously worked less efficiently, I am looking for reasons why?
@atrainor1 , Andrew, Some reasons why electric shavers loose efficiency. On electric shavers the blades can become dull, batteries can start to not hold their charge, motors can become weak from use/wear, the mechanical components can be seizing from hair/debri trapped around them making shaver work harder(overheating motor/battery), chargers can fail, internal gears can wear and lubrication can break down. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Make sure that the battery is charging and operating properly. If the battery is not the problem then you may want to check the razor head for hair buildup. The razor will not shave as well if it has too much hair inside the head. If it is clean and the battery is charged, then it may be time to replace your motor
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 13
All Time: 836
1 Comment
Student, iFixit Technical Writing Project
by L Pfaff
