Battery
1 Answer 0 Score |
My razor stopped functioning even after a full charge of the battery? |
2 Answers 0 Score |
Why is my shaver not working as efficiently as it did previously? |
1 Answer 1 Score |
Why does my razor keep getting hot? |
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
If you are having difficulties with the Panasonic Arc 3, try referring to the Panasonic ARC ES-LT3N Troubleshooting
Background and Identification
The Arc 3 has introduced a bunch of new editions since its original release in 2008, there have been 11 different models of the Arc 3. Specially designed by Panasonic, the powerful Arc3 3-blade system combines pure shaving velocity with multi-blade precision to cut gently and comfortably through facial hair. The shaving machine system's ultra-thin Nanotech blades are forged from premium stainless steel. And, each is precisely honed to a 30° angle for outstanding durability and sharpness to cut whiskers at the root for fast, smooth, efficient shaving.
The Panasonic Arc3 ES-LT3N-S Wet/Dry Men's Electric Razor combines pure shaving power with the gentle comfort and convenience of multi-blade shaver precision. A floating 3-blade system provides quick, smooth shaving while an advanced 3D multi-flex pivoting shavers head glides effortlessly over face, chin, jaw and neck. Hypoallergenic stainless steel blades, honed to an acute 30-degree angle cut whiskers more cleanly at the root and a pop-up trimmer instantly engages on the cordless shaver to cut stray hairs and detail sideburns and mustache. The 13,000 cpm fast, linear motor drive system eliminates the tugging and pulling that can occur with slower machines and also maintains high power right up to the end of each battery charge. Plus, with its 100 percent washable, wet/dry versatility, you can confidently use the Arc3 men's shaver in the bath or shower, over the sink and on the go.
Additional Information
Amazon Customer Review: Panasonic Arc 3
Shop Panasonic Device Features/ Specifications/ Reviews/ Accessories/ Support
