The Asus ROG Strix GL702VM-BHI7N09 is a gaming computer released by Asus in January 2017. It can be identified by the serial number on the bottom of the keyboard.
22 Questions View all
Why is my computer getting so hot?
The computer keeps reaching 100 degrees after I play for less than an hour. I've already tried placing it on a cooling pad, which worked with some of my other computers. I'm worried that these temperatures might cause an internal error with the computer.
Score 7
10 Comments
I just purchased ROG GL503V, 2 weeks ago. The laptop temperature rise up to 75 Celsius. I never even download or play any games. Just normal office use.
by
Because these computers are junk. I have been buying them for years thinking they are good. Then I spend 20 hours updating drivers and modifying GPU, cpu and more. Simply because ASUS is to lazy to put out good product that doesnt need tons of tweaking. My Omen didnt need a thing and out performs my 503.
by
I'm starting to think your way about Asus. I bought asus gl502vm, would shutdown during games. I repaste with mx-4 and k5-pro. Booted up, ran valley benchmark . It then shut off after I heard a muted pop. Then would not boot. Main board shows no visible damage, and capacitors looked fine. Don't know what's wrong. Disconnected battery before pasting...
by
I have a GL522VL with Core i7 processor. Overheating to the max. Disassembled and in removing the heat sink found three of the four anchors that screw down the heat sink to the processor had come loose from the motherboard. The heat sink was not being held down tightly to the CPU, so it was not absorbing and carrying away the heat. I'm going to try super glue to fasten the anchors, but this is not a good reflection on Asus.
by
dont buy asus laptops. i have the same problem like @hirichardshi. thats why i hate asus
by
Show 5 more comments
Add a comment
Chosen Solution
The Asus ROG Strix is a high end gaming laptop and should be able to handle higher temperatures very well. If you're still concerned, feel free to check out the troubleshooting guide here to diagnose your specific problem and see potential solutions. Hope this helps!
Add a comment
Most Helpful Answer
download Intel extreme tuning and change the core voltage OFFSET to -.080 or -.100 my temps are now at 79 to 85 c and it didn’t have any effect on my FPS just runs way cooler. this is a common issue on this laptop and ASUS calls this normal range at 100c!!! its way to hot
Score 3
10 Comments:
Hello! On your intel extreme tuning, what core voltage option did you changed to -.080? The yellow or the red i circled into my photo?
https://imgur.com/a/w9ncl
by
needs to be core voltage offset. sorry i should have made note of that.
by
This dropped my peak CPU temperature by 5 degrees Celcius. Very useful!
by
Thanks Im glad this has helped people!
by
Guys, Does this change in Core Voltage Offset can damage the CPU in any circustances? Besides which core voltage option do I change? There are two of them @ Chris C
by
Add a comment
If it's 100 degrees Fahrenheit that's absolutely fine and there is nothing wrong with that, if its 100 degrees Celsius, that's not great but for a high performance gaming laptop, it should be fine. Try turning down your game settings so the laptop doesn't have to work as hard and thus can work at a cooler temperature. If its still at 100 degrees Celsius and you turned down the settings report back here and ill give you other options.
Also, do you hear the fans spinning, and what program are you getting the temperature measurements from?
Score 2
1 Comment:
Most, if not, all software will report units in Celsius
by
Add a comment
100 degress c is not good for your notebook and your performance will suffer. It may even cause damage over time to you notebook.
I have the same notebook and went through an RMA process with ASUS to fix the problem of over heating and poor game performance. I sent the computer to them and got it back without anything fixed and no info on if they even did anything to it.
So I took matters into my own hands and removed the bottom cover of the laptop. Sure enough I was getting better performance and cooler temps by 10 degrees c!
It is a design issue with the laptop and more info and solutions can be found on this forum:
https://rog.asus.com/forum/showthread.ph...
Score 2
Add a comment
I have one too its just manufacturing error.
What you can do
1. Undevolt CPU with Intel XTU
2. Undervolt GPU with afterburner or asus tuning utility
3. Replace Thermal paste
4. Seal Third fan in pc to get better airflow
5.Drill Holes in bottom of pc
And best one is just to ask for refund if its not late. :D
Score 2
1 Comment:
Could you please explain the 4th point?
by
Add a comment
Hi Sydney,
Generally when using a laptop, you would want to avoid the bottom of the laptop from touching any material like a blanket or like your lap or anything that would stop air from going through the fans.
The ventilation could be blocked, which is bad, the air circulation is very important for cooling the internal hardware.
The laptop sucks fresh cool air and the hot air blows out. If there is a soft cushion (bed) or other material (not including rigid material) it blocks the vents which results in high temperature of the hardware of the laptop, this can make the computer 60 degree celsius and higher.
Higher temperatures can damage the internal hardware and decrease its battery life permanently, so try not to over work it :)
Score 2
1 Comment:
true..and so i lifted my notebook while playing about 5 inches with help of a custom made stand and my cpu goes to 93 max and gpu 75 max (degrees)
by
Add a comment
maybe if you just clean the cooling fan its good idea
Score 1
Add a comment
I’ve owned one of these for a month or so now, and I’ve found that the trick is managing performance vs heat. If you just max all of your graphics settings and have it plugged in, it will get hot and loud just like a desktop graphics card would. Note that the nvidia controls by default have Plugged in and Battery settings.
In my opinion, this is a great computer with a bit too much power that you have to know how to manage. (I like that)
You don’t need to drill holes in it :)
Score 1
1 Comment:
U just want to decrease the ' maximum processor power state ' in battery.. advanced setting...processor state ...to 65 percent when plugged in...and also use best performance avoid better performance ..no fps drops in games ..working temps between 61 to 72.thank.me later
Asus rog ..
by
Add a comment
Hello i bought asus rog gl531g and when i play games like csgo or dota the cpu and gpu temperator goes high sometihng like 70c or 80c or higher
anybody have an idea what can i do do cool it down ?
1 Comment:
installe MSI afterburner and Rivatunar ( its in the pack if you download from MSI web site) and see what are CPU and GPU max temp and what clocks they are getting.
beacause probebly its the graffic card with 2mutch power generating more heat.
by
Add a comment
Hello all
I know this is an olde post, but i guess i have the unser why this laptops are so f***king Bad. Even Asus support is worst!!! i really thing that they are all random people that doent know nothing about pc’s /hardware…..
The major problem of Asus GL502VMK comes from the GPU….
I have a GL502VMK with a GTX1060 6GB, and one thing i notice is that the graffic card is getting too mutch Voltage.
on a load she is getting 1.2V this generats more heat in addition to CPU heat starts to throttle.
The factory clock for the GTX 1060 6Gb is 1440mhz on a normal load, and 1660mhz boost load ( arround this) and i notice that on this laptop is making on a normal load 1710mhz and on boost 2005mhz, this means that the graffic card is overcloked…. generating more heat….
using MSI afterburner, and underclock the GPU, i was abble to run Apex legends with normal settings and 120fps without glitch and freeze and the temps on CPU arrownd 69º and graffic card 59º/65º ….
But this was resoult of 2years of research of sullution for this PC…. i have spend mutch money and couldnt play any games!! Despite of my attempt to see if asus could help and solve this problem, they gave me wrong info, and they dont know what the talk about…. them dont even know that is intel XMP profile….
1 thing is for sure, is that im will never get nothing from asus no more!!! im done with them….
Add a comment
Add your answer
Sydney Gray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 22
Past 30 Days: 82
All Time: 85,902
