Hewlett-Packard began manufacturing personal laptop computers in 1993.
3715 Questions View all
What are these white lines on my laptop screens?
I have noticed these white line on my laptop screen which are not noticable at all when looking at screen perpendicularly . But changing the viewing angles to like 170 to 180 degress these lines appears.
Here are the screen shots
http://imgur.com/a/aGA3S
2 Comments
Don't change viewing angles.
by
Viewing angles are not the problem when you are working with a laptop . ;)
by
Add a comment
Most Helpful Answer
Hook it up to an external monitor and iff the issue persists, the problem is with the GPU. If it goes away, change the LCD.
Score 3
1 Comment:
GPU is working fine. The lines are not noticable normally so I'm fine with the screen.
by
Add a comment
It's hard to tell from the pictures (They're a little too low res to differentiate the pixels) but it looks like it may be an issue with the LCD display itself. GPU failure would result in perfectly straight lines, but since this appears more 'organic' in nature, I have my chips on the layers within the display assembly coming apart. Do what Mayer said and plug the laptop into an external display. If there are no distortions on the external display, you will need to replace the display module.
Score 1
2 Comments:
It appears to me as if some layer of the LCD screen might have got separated.
by
bunkers excellent answer
by
Add a comment
Add your answer
anonymous100000 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 616
