Why has the sound stopped?
the sound has stopped all the functions are working but no sound
msthang332001, Make sure the Line In Switch is in the off position if not using the Auxiliary Input, make sure the line-in switch, located on the back of the system near the auxiliary cable, is in the off position. It may be a bad volume switch/connection, bad speakers/connection, possible fuse blown for internal amp. if equipped or could be a faulty amp. The guide 1st link below will help get you inside the device to check/test components. If under warranty have repaired/replaced/refund under the warranty. Last link is Crosley support page. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 19
All Time: 293
