Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
255 Questions View all
Crucial memory compatibility 8Gb
Does anyone know if the Crucial memory modules Crucial 8GB DDR3L-1600 SODIMM Memory for Mac are compatible with the iMac 14,1?
Crucial support wouldn't commit to say there are compatible .. as "Memory slots are not end user accessible".
Yet a number of sites claim they are Crucial 8GB 1600 MT/s PC3-12800 Unbuffered 204-pin SO-DIMM for Mac.
Anyone done the upgrade using the Crucial memory.
Thanks in advance
-Craig
4 Comments
Thanks @danj for the clarification.
Ok... what about OWC memory.
They have a sweet deal for memory + kit + adhesive = $140
(sorry ifixit.. you were > $211 for same :-( )
by
mmm... IFIXIT doesn't list the RAM for your system only a link to Amazon - Crucial 8GB Single DDR3L 1600 MT/s (PC3L-12800) SODIMM 204-Pin Memory - CT102464BF160B
So I'm not sure you found the best price ;-}
Crucial's Web site: $64.99 per 8GB
Amazon Web site: $61.24 per 8GB
by
Add a comment
1 Answer
Most Helpful Answer
First both are right!
Crucial is warning you there is not access door in the 21.5" models to gain access to the RAM slots (unlike the 27" models).
As far as the needed RAM the system uses PC3-12800 DDR3 (or DDR3L) modules. So you can get either type and you can boost your system up to 16 GB!
So lets get down to brass tacks here... The newer 'Thin Series' models are a bear to open! Make sure you use the correct tools and follow the IFIXIT guide to the letter as you can easily damage the display which would be an expensive Opps!
Here's the IFIXIT guide you'll need to follow: iMac Intel 21.5" EMC 2638 RAM Replacement. You'll need at least one set of adhesive strips to re-attach the display.
As reference here is someone who sadly didn't use the correct tools or didn't follow the proper technique to pull the display: Possible causes in vertical lines of LCD.
Score 1
Add a comment
Add your answer
Craig Haydon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 456
