The Canon PowerShot is a 5.0 megapixel camera with 4x opitical zoom.
14 Questions View all
usb pin came loose
In regards to my Canon PowerShot A610. The usb port on my camera has come loose and is floating around in the camera. There are three small screws that house the USB. I am unable to attatch a usb cabel to the camera. Can I fix this by snapping it in or do I need to send it in?
Score -1
Add a comment
1 Answer
Chosen Solution
Canon Powershot A610 Camera Housing Replacement
take a look at this guide for how to remove the outer case on your camera. Once you have done this you may be able to locate the loose part and work out how to reattach it without the need for sending your camera to a repairman...which will probably cost more than the camera is worth!
Score 2
2 Comments:
+ Great advice
by
Or if it can't be fixed using pollytintop's answer,you have to buy a mini USB female end and replace it using the same guide
by
Add a comment
Add your answer
Joey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,237
