Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4709 Questions View all
How to get lotion out of my speakers?
So I was hanging out in my room and the new Playboi Carti album came out and I started dancing and I accidentally knocked off my open bottle of lotion which happened to land on my phone and some of the lotion managed to slip inside my bottom speakers (near the home button) and now it sound really muffled, like really bad any idea of how to get it out I looked everywhere and I have no solution
Score 1
Add a comment
Try scraping the location out of the speaker grill first and if that doesn't work then try below
Make sure your phones battery is completely discharged to be safe then get some 99% isopropyl alcohol you most likely can get this at your local pharmacy put it into a container and let your phone soak completely submerged for 20-30 mins then take it out and sake it gently to get most of the alcohol out then let it dry for about an hour DO NOT use anything lower than 99% alcohol the water in anything less could corrode the logic board the alcohol should dissolved any location that stuck in the speaker
Score 1
3 Comments:
Does 50% isopropyl alcohol work?
by
In theory yes, but there is also a lot of water in that. It would most likely corrode the metal contacts on the logic board.
by
Will 70% work?
by
Add a comment
Most Helpful Answer
Iphone 6 speaker located under home button has 6 exit holes with a mesh... that mesh I assume have held all your lotion. Try to scrape it off with toothpick
Score 1
1 Comment:
Mr Eigirdas Gedgaudas thanks
Your solution worked a little bit
by
Add a comment
Add your answer
Kyro G will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 6,686
