Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
90 Questions View all
Can someone identify this component
Hi can anyone help identify the component which should be located in this photo circled in red , it was missing and the small component next to it was off its pads looks like pry damage to me .
It is near the short connector which go's to the display.
zxw tools doesn't seem to be much help with this board ..
Board is 820--00180-B .
Score 1
2 Comments
Hey, were you able to resolve the issue? Was it a bad screen? Was it the Tristar Chip?? I’m having power issues with mine
thanks
by
@travelpro85
Hi , no this one went into the box of spare parts ..
by
Add a comment
Chosen Solution
I just checked a mini 4 board I have on the bench. This is a 100K / 01005 resistor acting as a pull-down. This is similar to the circuitry on the iPad mini 2 (see R2241 on page 19 of the schematic).
Score 3
2 Comments:
Thats great , thank you , do you also have the correct orientation of the 1610A3 chip , it looks like this has also been replaced , i want to check it is on correctly .
As when i connected the charging cable i had the apple logo briefly then connect to itunes but back to black screen as soon as cable is removed .
it will not connect to itunes on pc either , so im thinking maybe the tristar chip not fitted properly judging by the pry damage .
by
If you look at the logic board length wise, with the WiFi Ic to the right, then the dot on Tristar is at the top-right hand corner.
by
Add a comment
thanks for your help , just to be certain , this is correct ? .
3 Comments:
Yes, that's good.
by
Hi again , ive replaced the chip , still no joy , could you please check your board to see if there should be a component on the pads to the left of the cap just above the chip in the photo ,
From the limited zxw board view it seems there should be .
by
Very strange symptom when plugged in see video , https://www.youtube.com/watch?v=7lG82F3j...
could this be because the screen is smashed ? . The battery is dead flat too.
by
Add a comment
Add your answer
markparnell1972 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 864
