The Samsung HLM or HLN series is a line of projection televisions.
29 Questions View all
The picture no longer shows picture yet still has sound. The issue?
The picture on the Samsung Slim DLP TV no longer works. It left suddenly the other day. A few days prior, it began making a slight crackling noise especially when first turned on. The sound is still in tact. Here is the TV info.
Model No. : HL-T4675S
Serial No.: AHE83CMP800808L
Version: PA01
Lamp Code: BP96-01653A (P132W)
BP 88-00633A
Model Code: HL T4675SX/XAA
Please advise of what the issue likely is and how to proceed with fixing it.
Thank you!
Add a comment
1 Answer
With the cracking sound, I would suspect that the lamp ballast has failed. If you have a spare lamp, try that first. It is possible that the lamp has failed and made that noise. Otherwise, I would suspect the ballast. The ballast is what triggers the lamp to start similar to a starter in the older fluorescent lamps.
Dan
Add a comment
Add your answer
Ray will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 59
