Is This Safe To Plug Into an extension cord or power strip?
Hi @bunnybunny
Use the below link for a gauge.
https://www.electricalsafetyfirst.org.uk...
For safety , do not overload those.
Typically for this type of device, it is not recommended to use any type of extension cord. If you must use one due to placement for safety, use one rated for the current required by the fireplace. This should be marked on a plate on the back. If in doubt, use a cord with a higher rating. In other words, if this is rated to use 15 Amps of power, I would recommend at least a 14 gauge extension. Better still would be a 12 gauge.
Keep the extension as short as possible too.
Check with the local electrical inspector as well. Sometimes, insurance won't cover a loss if something is done counter to standard practice or recommendation.
Dan
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 333
How many AMPs does it pull?
by mayer
