No picture, vertical lines
I have a 60 inch LED, model # UN60ES8000F XCZ
I have no picture and a color screen with vertical lines. The tv goes off and tries to turn on again. I've unplugged and let it sit for awhile , the picture comes back for a bit then the vertical lines then it shuts off and tries to start, sometimes it gets to the log on screen ten shuts off, then tries to start up again. Any recommendations?
thanks
Update (08/16/2018)
Hey guys thanks for the replies, I just had a hip replacement. I'll get pictures and catch up once I start healing
Update (09/27/2018)
Hey guys i`m back, For an update, i plugged the tv in and without any video feed to it, it worked flawless. I did a picture test , left it plugged in for a week and it worked fine. I then hooked it up to a satellite receiver and within 10 minutes it i had a funny colored screen and the tv shut off and the tried restarting, ill post some pics.
thanks
9 Comments
any help would be appreciated
by Boyd Holmen
@prairiedog as @absrvc already pointed out it will help if you can post some pictures of what your screen dispalys and what the boards look like. Use this guide Adding images to an existing question for that. I would not suspect a T-con board error to cause this behavior "tv goes off and tries to turn on again" sounds like a main board or power board issue
by oldturkey03
@prairiedog sounds like a great idea:-). Take care of the hip first. The question will wait. Speedy recovery and all the best to you.
by oldturkey03
sorry, i guess this was a comment not a answer
by Boyd Holmen
any ideas what can be causing this? Thanks for all the help so far
by Boyd Holmen
Show 4 more comments
