The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Questions View all
Samsung galaxy tab 4 Tablet reboots every 15 minutes?
After not using my tablet for about 6 weeks I struggled to get it to charge. After buying an original samsung charger its all sorted but not the tablet reboots every 15 minutes.
Following other suggestions I cleared the cache in asr mode, and have also done a full wipe in asr mode. Now it loads up connects to the wifi and then reboots every 15 minutes or so.
Any ideas? TIA ☺
13 Comments:
I am assuming that what you mean by a “full wipe in asr mode” is that you have tried to do a factory/hard reset?
https://www.technipages.com/galaxy-tab-4...
by
Hi, Yes. Full factory reset by turning tablet off. Holding power, volume up and main button down until android symbol appears and then rebooting.
by
Sounds like a chip fault, changing the battery might help but it sounds like it’s on it’s way out.
by
Hi,
Does it do this with the charger connected and switched on?
by
Not tried that but will do that now and get back. Thanks!
by
Show 8 more comments
Add a comment
1 Answer
Since i had many tabs that response badly when battery needs to be replaced i would try that first. Otherwise iT can be a heating problem. But my guess is changing the battery Will work.
Add a comment
Add your answer
Nichola will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 22
All Time: 196
