Apple's 2016 revision to their laptop lineup targeted at professional users. Features a 15-inch, 2880-by-1800 Retina display, quad-core Intel Core i7, 256 GB / 512 GB /1 TB / 2TB storage options, 16 GB RAM, and a keyboard equipped with a Touch Bar. Released November 2016. Features Model A1707.
264 Questions View all
Cracked MacBook Pro 15 bottom bezel
I crakced my macbook pro’s bottom bezel, first day display was fine.. now a black strip appear..when tap on that cracked portion. That area color is reverting the color of actual screen..
So costly to replace entire screen.. please help..
Update (01/12/2019)
Is it possible to change chin plate? When clicking there color is inverting with black color when tap on that cracked portion. That area color is reverting the color of actual screen.
1 Comment:
Same thing happened to me.. so gutting. Happened within months of getting the device. Can’t afford to repair it
by
Add a comment
Review this guide: Replace the LOGO Baffle on the screen with the MacBook Pro 15 "Touch Bar 2017 logo. You’ll need to order the plate from eBay Front Glass Bezel LCD Logo Cover Trim MacBook Pro 15"
Update (01/12/2019)
OK, Thats not good ;-{
The chin plate covers the edge of the LDC panel’s fragile contacts. Your LCD panel is also damaged! You can’t do anything to fix it other than replace it. Unlike the older models this series as the T-CON board mounted in the main case so more lines are needed to move data from the case to the lid as you can see here:
You have no choice here you need a new display assembly MacBook Pro 15" Retina (Late 2016-2017) Display Assembly Apple P/N 661-08031
Replace a display compatible with the model A1707 late 2016 to 2017 Retina 15" MacBook Pro laptop. Includes the 2880 x 1800 15.4" Retina LCD Screen, Display Cover, Bezel, Camera. Image
Product
$507.99
4 Comments:
Does it will help to get my display back to normal? I mean that black area..
by
OK, thats a different issue! This only addresses the chin plate damage.
So your screen has an issue too! Post a picture or two here for us to see Adding images to an existing question
by
If the bezel i cracket, will it interfiere with the brigtness of the display or colors? Im thinking og byeing at mac with a crackey bezel.
by
@Lars Ulmer - It could! The ribbon cables are just behind the plate so they could become damaged. Review the images in this guide Replace the LOGO Baffle on the screen with the MacBook Pro 15 "Touch Bar 2017 logo
by
Add a comment
There are ribbon cables connected to the screen that hide behind that small chin bezel. When you smashed the bezel in you must have hit one of those cables…
Add a comment
Add your answer
max wright will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 12
All Time: 9,100
