First, it should be covered under warranty!
Cause 1
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the door lock is defective, the washer door will not latch properly. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Cause 2
Door Lock
The door lock assembly might be defective. Inspect the door lock for damage. If the door lock is damaged, replace it.
Cause 3
Door Latch
The door latch assembly might be defective. Inspect the door latch for damage. If the door latch is damaged, replace it.
Cause 4
Door Strike
Inspect the door strike assembly for damage. If the door strike is broken, replace it. The door strike is not repairable—if it is broken, you must replace it.
Parts
Cause 5
Main Control Board
The main control board may be defective. However, this is rarely the case. Before replacing the main control board, first check all of the components of the lock mechanism. If none of these parts are defective, consider replacing the main control board.
10 Comments
This answer sounds crazy Bc I have this problem all the time. It click click clicks on and off and the "lid lock" will start blinking" and the only way to turn it off is to unplug it. I think it's something with the weight distribution error. I spin the washer around with my hand crazy fast and blow into the lid lock and the lock and than slam the lid down and walaa. Works every time lol. Sometimes I have to do a few cycles of my
Manual hand spin but luckily it works. The click turns on when it goes to spin and stops the spin each time.
by Tonianne Violi
My lid switch failed, so I replaced it, with a new part, from Maytag. Installed the new switch, and the solenoid is only making an intermittent buzz/click noise.
Last of these washers I’ll ever buy.
by Jake Thetool
arrgh... mine is 6 days left in warranty - BUT I cannot find the receipt. Only able to see the purchase on my credit card - not even able to see specific merchandise I bought, so doubt whirpool would honor it. The lock "tries" to engage then clicks off. Cycle goes straight to "done" - no wash. Lock light never came on. Pulled out the switch and tried the "bypass" many mention on yourtube - nothing, not even the clicks. Put it all back and it does the clicking - only this time it cycles through the attempted lock/fail (double click) 3x - six 'clicks.' Arrgh... guess I'll order a new one. Should've written down the part number when I had it apart.
by michael sullivan
Happened this morning gotta try it now, cause I don't have 500 dollars for another one!!!!! Fingers crossed
by Colleen Willard
Just happened to me today. Yesterday it was fine. I also unplugged in frustration plugged back in and slammed the lid. That apparently worked as I was looking this up here and typing. Crazy!
by Ellen Benedetto
Show 5 more comments
