Service and repair information for the Huawei Mate 8, which was released in November 2015. It runs Android OS, v6.0 and sports a 6.0-inch display. In addition to a 16MP primary camera and an 8MP secondary camera, the Huawei Mate 8 also has a non-removable Li-Po 4000 mAh battery.
15 Questions View all
touch screen not working after lcd screen replacement
after lcd screen replacement touch was working fine but after few hours it stop working and then tried with other new screen replacement but touch screen not working but display is fine
Score 4
2 Comments
hi
I have this problem too, in the top of the lcd socket, some parts of resistants has been breacked
but i dont find this parts to reinstal them and exactly dont know this problem directly affected to touch or not.
by
How can solve this
by
Add a comment
1 Answer
Most Helpful Answer
If the screen was an cheap-repleacement part then it could be not suitable for your device. The good practice is to manage a hard reset of your phone after any replacement in order to get a new drivers adjusted to your component. Try that and then you should consider an PCB damage - not only the connector but whole ICs itself. The first thing that goes off when some one not provided goes into the device is an backlight IC, but in your case it could be just touch circuit.
Try a new display after an hard reset of device. Then go back to this forum and get better answer than mine.
Ps. After reading your post over again I would suggest to check for water damages. If the screen stops working after few hours it could be some dirt/corrosion on the motherboard near chips/capacitors
Score 1
Add a comment
Add your answer
darshan kumar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 23
All Time: 9,139
