Back Cover
1 Answer 4 Score |
touch screen not working after lcd screen replacement |
1 Answer 0 Score |
when I get a call poeple cant hear me |
1 Answer 0 Score |
Why is touch screen usually not worked? |
3 Answers 0 Score |
Does changing the battery also require us to change the screen? |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
(NXT-L09) Single SIM, (NXT-L29) Dual SIM
Background and Identification
The Huawei Mate 8 Android smartphone was produced by Huawei as part of the Huawei Mate series. The Mate 8 was released in China in November 2015 and globally in early 2016. The Mate 8 was available in gold, silver, grey, and brown variants.
The Mate 8 has a 6.0-inch Gorilla Glass display and an aluminum back and frame. The Mate 8 includes a 16-megapixel main camera and an 8-megapixel selfie camera. The phone was sold with 32 GB of internal storage and 3 GB of RAM or 64 GB of internal storage and 4 GB of RAM. The Mate 8 and its successor, the Mate 9, both include a 4,000 mAh non-removable battery. Both phones can also support expandable internal storage with MicroSD cards up to 256 GB. The Huawei Ascend Mate 7, the Mate 8’s predecessor, actually has a larger 4,100 mAh non-removable battery, though the dimensions of both phones are nearly identical.
The Mate 8 features fast-charging capabilities and a rear-positioned fingerprint sensor. It also includes accelerometer, gyro, proximity, barometer, and compass sensors.
While reviews found that the Mate 8 had clunky software, a less-than-impressive camera, a low-resolution display, and average speakers, the Mate 8 has been praised for outstanding battery life and above-par performance.
Technical Specifications
Models: NXT-AL10, NXT-CL00, NXT-DL00, NXT-TL00, NXT-L09, NXT-L29
Release date: November 2015
Body:
- Dimensions and Weight: 157.1 x 80.6 x 7.9 mm (6.19 x 3.17 x 0.31 in), 185 g (6.53 oz)
- Build: Glass front (Gorilla Glass 3), aluminum back, aluminum frame
- SIM:
- Nano-SIM - NXT-L09
- Hybrid Dual SIM (Nano-SIM, dual stand-by) - NXT-L29
Display:
- Type: IPS LCD capacitive touchscreen, 16M colors
- Size: 6.0 inches, 98.7 cm2 (~78.0% screen-to-body ratio)
- Resolution: 1080 x 1920 pixels, 16:9 ratio (~368 ppi density)
- Protection: Corning Gorilla Glass 3
Platform:
- OS: Android 6.0 (Marshmallow), upgradable to 7.0 (Nougat), EMUI 4
- Chipset: Kirin 950 (16 nm)
- CPU: Octa-core (4x2.3 GHz Cortex-A72 & 4x1.8 GHz Cortex A53)
- GPU: Mali-T880 MP4
Memory:
- Card slot: microSDXC (uses shared SIM slot)
- Internal: 32GB 3GB RAM (L09, L29), 64GB 4GB RAM (L29)
Main Camera:
- Single: 16 MP, f/2.0, 27mm (wide), 1/2.8", PDAF, OIS
- Features: Dual-LED dual-tone flash, panorama, HDR
- Video: 1080p@60fps, 1080p@30fps, 720p@120fps
Selfie Camera:
- Single: 8 MP, f/2.4, 26mm (wide)
- Video: 1080p@30fps
Sound:
- Loudspeaker: yes
- 3.5 mm jack: yes
- 24-bit/192kHz audio
Communications:
- WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, DLNA, Wi-Fi Direct, hotspot
- Bluetooth: 4.2, A2DP, EDR, LE
- GPS: Yes, with A-GPS, GLONASS, BDS
- NFC: Yes
- Radio: FM Radio
- USB: microUSB 2.0, USB On-The-Go
Features:
- Sensors: Fingerprint (rear-mounted), accelerometer, gyro, proximity, barometer, compass
- ANT+
Battery:
- Non-removable Li-Po 4000 mAh battery
- Charging: Fast charging 18W, 37% in 30 min (advertised)
- Stand-by: Up to 528 h (3G)
- Music play: Up to 98 h
Miscellaneous:
- Colors: Champagne Gold, Moonlight Silver, Space Gray, Mocha Brown
- SAR: 1.49 W/kg (head) 0.32 W/kg (body)
- SAR EU: 1.46 W/kg (head) 0.21 W/kg (body)
