Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1097 Questions View all
iPhone X boot loop after (slight) water damage
On vacation I accidentally fell into the sea with my iPhone X. It was just for a brief 20 seconds until I got out of the water. The iPhone continued working for a long period, but I noticed that my Face ID was currently unavailable. Later that evening, my iPhone died and I wanted to charge it. This was working fine, until I needed my iPhone, not knowing it was water damaged, I unplugged it causing it to die again a little later. From that moment, it wouldn't boot up anymore and it got stuck in a boot loop. Now, I realised that my phone was water damaged. I decided to put it in rice for a day. After that, I tried to boot it but it didn't do anything anymore, not even showing the apple logo. I was worried because of this and decided to let it rest a couple days more in the rice. After that, I charged it and it did boot up -> showed the apple logo -> then died again. I thought that my battery was damaged, so I decided to replace it myself. This fixed the problem of my iPhone dying but now it's just back in the boot loop. I stumbled on some YouTube videos and saw that the boot loop may be caused by some water in the connectors. I decided to clean all my connectors with isopropyl but unfortunately this didn't fix anything. I'm kind of worried now because even none apple repairs are really expensive in the area where I live and as a student I saved really long to just buy this phone, let alone buying a new one. Is there anything else I can do or try that may fix the problem? I do really appreciate the help! Thank you so much in advance.
Some sidenotes:
- the iPhone barely looks waterdamaged when I opened the phone
- I saw some vapor in the Face ID before I put in into rice, this is already gone
Add a comment
Most Helpful Answer
First off all never use rice again. It doesn’t do anything. The very first thing you want to do when your phone comes in contact with water is turn it off. You then need to take the phone apart and clean the board with 91% or higher isopropyl alcohol. Then you let it dry out for around 24 hours put it back together and hope for the best.
Score 1
Add a comment
Maybe the internals were damaged. Did you contact apple? Maybe they can give you a replacement phone.
Add a comment
Add your answer
lucas.verhoest will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 710
