Model number NV370. Stands 27 inches tall and features Shark’s never loses suction technology and swivel steering.
26 Questions View all
Roller brush doesn’t turn - Shark Lift-Away brand
I have a Shark Lift-Away, the brush has stopped turning. I have cleaned it, etc.
Score 1
2 Comments:
My roller also stopped working. It would be nice if you could remove brush to see if there is hair wrapped around where the brush connects.
by
@yazminkuba18603 You can remove the brush, but it's not just a matter of snapping open a couple of latches on these machines; there are like 10 screws that have to be taken out but it is doable.
Shark Navigator Roller Brush Replacement
by
Add a comment
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
2 Comments:
That instruction is basically clean it, it doesn't have an answer.
by
Mine just doesn't work no .atter what I do
by
Add a comment
have check all obvious problems but brush roll wont turn
2 Comments:
I'm having the same issue. Is there a reset button for the beater bar(brush roller)?
by
Mine won't even turn manually.
by
Add a comment
Brand new right out of the box will not pull or push spin brush does not work.... WTF is the problem with this vacuum
1 Comment:
Take it back, why worry?
by
Add a comment
It is either:
A stuck brush because of debris
A bad or broken belt
A bad switch or connector
A bad brush motor.
Add a comment
Add your answer
Barbara Glosson will be eternally grateful.
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 97
All Time: 5,522
