Repair and troubleshooting information for the HP Pavilion dv6000, an HP laptop part of the HP Pavilion series. Released in April 2007.
Battery is stuck in laptop.
How can I remove the battery to check if it has been recalled.
Score 1
1 Comment
How is the cover stuck? Can you post a picture?
by
Add a comment
Chosen Solution
To remove the battery move the battery hold latch to the right and tilt the battery out. See attached pic :-) be careful when you pry with anything, so as in not to break the housing etc. To check the eligibility for the battery recall check on this website it will give you the proper procedure and numbers. Good Luck.
Score 4
3 Comments:
make sure you unlock the clips first
if they are in right position just turn laptop upside down or help with a knife or something
by
heyy thnx for the response but it seems like the battery latch is stuck and not moving
by
i have the same problem on my dv7
by
Add a comment
what if the latch is broken
Add a comment
Add your answer
Donna Durand will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 5,271
