A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
214 Questions View all
sprays during rinse cycle
i have a roper washing machine rtw4640yq0. when i wash clothes during the wash cycle the tub fills with water and washes fine, but when n it goes into rinse cycle the tub does not fill with water it sprays the water while draining and the tub does not fill with water. is the tub suppose to fill with water during the rinse cycle or does it just spray water while draining? thanks
Add a comment
Chosen Solution
The newer washer won’t fill up for a rince, they spray while spinning the clothes. You should have a 2nd rinse option or similar to get a full rinse. The owners manual will explain the cycles and operation. Good information in the owners manual.
Score 3
1 Comment:
Hello LadyTech. Question you might know. Have Kenmore model # 11020922990. I have no water filling problem, or water discharge/draining problem as "I fixed the inconsistent fill level & no water during rinse issue" by changing the water level/pressure switch (added the tube clamp, but didn't change the tube yet). Ran several times and all is good EXCEPT, the only issue I think I have now is that it's seems to only spray a little water for about 30 seconds during the rinse cycle after the water drains out? It used to spray more/longer before it goes to the "spin" cycle? Owners manual has no info; Whirlpool doesn't know the schematics, or care. Your thoughts?
Thanks.
by
Add a comment
Most Helpful Answer
Sounds like it’s working as designed to me.
Score 3
2 Comments:
Question sir: I have no water filling problem, or water discharge/draining problem as "I fixed the inconsistent fill level & no water during rinse issue" by changing the water level/pressure switch (added the tube clamp, but didn't change the tube yet). Ran several times and all is good EXCEPT, the only issue I think I have now is that it's seems to only spray a little water for about 30 seconds during the rinse cycle after the water drains out? I thought that it used to spray more/longer before it goes to the "spin" cycle? Changed the water inlet valve about 6 years ago, but do you think it could be an issue? Your thoughts?
Thanks.
by
Yea. My SpeedQueen fills, spins, drains and when almost drained sprays for about 30 seconds and then completes the spin cycle.
by
Add a comment
Add your answer
greg will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 25
All Time: 938
