The HP Spectre x360 13 -ac023dx is a compact laptop which is light, powerful, and has smart security features.
6 Questions View all
2017 Spectre x360 back panel removal?
Im trying to remove the rear panel from my 15' x360 to upgrade the ram. I took out all the visible screws but then also knew there were supposedly screws under the back feet, however i tried pulling off the rubber feet and under was this, pictured below. the feet were on with adhesive and these plastic pieces are on help on very strongly. Ive tried prying with all sorts of tools but cant get them to move. I Dont see what im seeing in any online guides so im a bit confused. How do I get these off? PS. the selected device is not my exact model, but the closet I could find in the device list. Thanks!
1 Comment
Do these maybe unscrew or do you have to pry them open?
by
Add a comment
1 Answer
Most Helpful Answer
Hi,
Here’s the maintenance and service guide for a HP 15 x360 laptop. You don’t state the full model number but this manual is dated 2018 so hopefully it should be OK
Go to p.30 to view the necessary pre-requisite steps and then the procedure to remove the bottom cover.
Score 1
Add a comment
Add your answer
Ethan Hall will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,470
