Battery
2 Answers 1 Score |
Automatic white random spots on screen |
1 Answer 0 Score |
2017 Spectre x360 back panel removal? |
1 Answer 1 Score |
The keyboard light turns on but screen is black |
1 Answer 0 Score |
When I close my laptop and open it again it says no bootable device. |
Documents
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Models
HP Spectre 13-AC023DX
Background
The HP Spectre x360 13-ac023dx is an extremely light weight laptop. At only 1.32 kilograms (or just under 3 pounds), the device can be transported easily at a compact size. The screen measures at 13.3 inches, which is on the smaller side for a laptop. It features an Intel Core 17- 7500U with Intel Burst Tool Technology. Its power supply is a 45 W AC power adapter.
The device has a full-size island-style keyboard, which uses keys in the shape of small squares with rounded corners and straight sides. It has a touch screen which measures in at 1920 x 1080 millimeters (mm). The HP Spectre x360-ac023dx’s minimum measurements are 30.7 x 21.8 x 1.39 centimeters (cm), which shows how compact the device is. The device has features such as an external port for both headphone and microphone, and an HP ImagePad which has multi- touch gesture support. This allows the touch screen to recognize the presence of more than one point of contact.
Identification
The HP Spectre x360 13-ac023dx laptop can be identified by the model number printed on the label located on the bottom of the device. If the label has been removed, you can find the model number beneath the battery. For additional help with identifying your device, visit the HP Support page.
Specifications
Product number
Z4Z21UA
Product name
HP Spectre x360 - 13-ac023dx
Microprocessor
Intel® Core™ i7-7500U (2.7 GHz, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
Memory, standard
16 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
Intel® HD Graphics 620
Hard drive
512 GB PCIe® NVMe™ M.2 SSD
Display
13.3" diagonal FHD UWVA BrightView WLED-backlit narrow bezel multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
HP Imagepad with multi-touch gesture support
Wireless connectivity
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
External ports
1 headphone/microphone combo; 2 USB 3.1 Type-C™ Gen 2 (Thunderbolt, Data up to 40 GB/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 (HP Sleep and Charge)
Minimum dimensions (W x D x H)
30.7 x 21.8 x 1.39 cm
Weight
1.32 kg (2.91 lb)
Power supply type
Battery type
3-cell, 57.8 Wh Li-ion
Webcam
HP TrueVision FHD IR Camera with dual array digital microphone
Audio features
Bang & Olufsen; HP Audio Boost; Quad speakers
Source for specifications: ++HP Customer Support Knowledge Base++
