Released November 4, 2017. Model A1865, A1901. Available as GSM or CDMA / 64 or 256 GB / Silver or Space Gray. (Pronounced the same as "iPhone 10.")
1096 Questions View all
iPhone X is dead
Hello.
A customer recently came in with he’s iPhone X and explained that it just died. It won’t turn on and it won’t charge.
I tried charging it while using a USB voltage meter and it showed 0A. I suspected the battery and tried to replace it but still no sign of life or charge in the phone. I then connected the phone to a DCPS to check if there is a short in the motherboard but it showed no short at all. I suspect one of the IC’s related to power management is dead but i am not sure where to start.
Anyone with similar issue that has a fix or can tell me what to do next?
Thanks in advance.
Add a comment
Sounds like a board level issue. Send it to a board repair specialist like iPad Rehab or STS Telecom or Louis Rossmann.
1 Comment:
I know it's a board level issue. "I suspect one of the IC’s related to power management is dead but i am not sure where to start."
I do board repairs myself but have never seen this issue in an iPhone X. I was hoping i could get someone who has experienced this issue before to tell me where i should star. That way i,m saving time.
by
Add a comment
You can check DM readings on the FPC’s to see if anything is off… check voltage readings at battery terminal FPC to see that Tigris and Hydra are doing there job… I have also seen middle layer with separated pads that needed jumpers and others needed a reflow. What does it do on booting from DCPS? does it connect to 3utools (computer)?
Add a comment
Add your answer
Total Repairs AS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 133
