Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
202 Questions View all
Why is my iPad Air 2 screen not working?
The screen will not work. The touchscreen will, and all interference is comes from the too big screen protector on it due to a hideously cracked screen. I think that the screen cable was dislodged on the impact of that cracking, and was jostled around too much and disconnected. Could this be true? Is it worth it to repair or should I replace it.
Oh yeah, the entire chassis is bent at a 3 degree angel from the charger port
1 Comment
The internals are visible through missing chunks in the glass at the bottom not on the screen
by
Add a comment
1 Answer
Chosen Solution
Can you post a picture of the damage? It would take a lot to knock the connector loose in your iPad because there’s a metal plate the covers the screen connectors and it’s held in place with 3 screws. I would imagine you damaged the LCD which is what puts the picture on the screen. In the Air 2 and other models, Apple glued the glass and LCD together but in your case, even if they were separate parts, you’d still need an LCD screen replacement. You should be able to order a kit here on ifixit. If the frame is bent, you’re gonna have a hard time fitting a new screen so you’ll have to try to straighten it out.
7 Comments:
Give me a bit, I’m not near it but I will do so
by
It’s there now. If you need a better angle I can get one
by
@Tsar_ Bomba yeah I'm gonna need more pictures from a few different angles if you could. Can you get a better pic of this bend you're referring to along with the internals?
by
Ok. The bend is not much of interest but ok
by
The bend does not exist. It was a hyperbole in my memory
by
Show 2 more comments
Add a comment
Add your answer
Tsar_ Bomba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 149
