Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
295 Questions View all
Won’t startup fully (I need help)
The iMac, with no modifications, heats up and takes over an hour to boot. When it does boot it dosen’t work.
Internet recovery won’t work. It loads then it says an error ocrred and then it restarts
please comment if you need more info.
Add a comment
1 Answer
Chosen Solution
Reload your system from the original system installation DVD.
Pre-Installed MacOS:X 10.6.1 (10A2155)Maximum MacOS:X 10.13.x*
Score 3
3 Comments:
The disk will go in for a second then pop out
by
Put the disk in partially. Hit the power on button and immediacy push it all the way in and hold down the c key.
by
I fixed it. Turns out the drive was messed up so I just changed it for a better one
by
Add a comment
Add your answer
Tsar_ Bomba will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 112
