Repair guides and support for your Philips TV.
251 Questions View all
Having power problems Philips T.V. (Model no 42PFL5603D)
When I turn on my Philips T.V (Model no 42PFL5603D/ 10), the power light comes on. No picture. After 2-5 seconds it seems to switch it self off. Has anyone got an idea of what to do, or how to fix it. Would be much appreciated
Score 1
Add a comment
Most Helpful Answer
bad capacitors are a good suspect. Sometimes the power LED will flash a code indicating where the problem is. But if it is a power problem it may not. Most of the time bad caps can be identified visually by observing if the top is bulging. It must be flat or slightly concave. If they are far gone they may even be leaking.
Score 1
Add a comment
It's most likely bad capacitors inside on the power supply board. Radio Shack sells a recap kit just for your problem. If you know how you can change these capacitors your self.
Add a comment
Add your answer
Paul Wheeliker will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 130
