The Husqvarna YTH20K46 is a 24-horsepower lawn tractor or riding lawnmower with a cutting width of 46 inches.
11 Questions View all
My lawn mower runs but cuts off when engaging the blade
I have a craftsman riding mower and it idle’s up and down, then when you try to engage the blade it cuts off I have changed spark plugs, cleaned the blades, and checked the belt, all is fine
I need some suggestions on what I should check next I was going to check to see if the fuel solenoid is bad that it's not getting enough fuel to operate the blade but not sure
Please help thanks and God bless
Add a comment
1 Answer
When the blades are engaged the throttle is adjusted to support the load. It sounds like that linkage isn’t working.
Add a comment
Add your answer
douglasbeverly1854 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 355
