Acer Aspire 3 A315-21-92FX is a series of with budget computers designed and sold by Acer. It is one of the cheapest computers in the market. The camera is equipped with 720 pixels HD webcam.
17 Questions View all
Why does it keep shutting off after it goes to sleep for a while?
I plug in my laptop and it is on and running fine. I walk away for an hour or more and then find that it is completely shut off. I don’t know why this keeps happening. I looked at my settings and don’t see anything set to make it do this. Does it need a new battery?
Add a comment
Most Helpful Answer
click START and type control. CONTROL PANEL will show at the top. Click that. When it opens click POWER OPTIONS. In there you will find options to set when the unit sleeps and when it hibernates. There are also different power options available and all contain those settings.
Score 2
1 Comment:
Thank you! I noticed it did say to turn off after 5 minutes in the advanced setting tab of that area. Hopefully this will do the trick. Thank you so much!
by
Add a comment
My HP Pavilion 14m-cd0001dx has done a similar thing after I re-installed Windows during an SSD upgrade. I believe it is due to a feature in Windows 10 where it will hibernate (essentially saves contents of RAM to hard drive, then powers off) after being in sleep mode for a certain amount of time in order to save the battery. There should be an option to turn that off somewhere in the power settings although I unfortunately forget exactly where. I would check that first.
Add a comment
Add your answer
Valerie Konitshek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 40
