Two year old LG tv screen went black while watching. How do I fix this
Watching tv & all the sudden the screen goes black, audio is fine. We have unplugged power source, no help. There is no HDMI cable. Please help. It’s only two years old
5 Comments
Hi @geema17,
What is the full model number of the TV as found on the information label that is usually found on the back of a TV?
Does the LG logo display on startup?
Can you view the TV menu screens OK?
With the TV on with audio try shining a torch at an angle close to the screen and check if you can see any images at all.
They will be very faint so trying this in a darkened room may help to see them if they are there.
If you can see images then there is a backlight problem with the screen, either the LED backlights, the power to the backlights or maybe the mainboard signalling the backlights to be on or off. This is of course unless it is an OLED TV then there are no separate LED backlights as the screen pixels produce their own light
by jayeff
Full model # is: 55UK6500AUA ; purchased 5/2019
No logo is showing upon startup. We aren’t able to see anything on the screen at all; no menu, volume; nothing at all; just a blank screen. We were watching it and it just went blank without warning.
We did attempt shining a flashlight on the screen but weren’t able to see anything. Not sure if our light isn’t bright enough or what….
by Elizabeth Welch
@geema17
Bit confused.
Is there audio or not as you initially said "...audio is fine..." but now say "... no menu, volume; nothing at all; just a blank screen."?
If no audio is there a standby power light? If so is it changing colour when the TV turns on?
by jayeff
I apologize for the confusion….Yes, we have audio; my answer was referring to your question of whether or not we are able to see the menu. We are not able to see anything at all of any menu; channel info, volume info, etc.
this morning when I power on the tv, I see a slight coloring variation, but still no picture
by Elizabeth Welch
Black screen
by ankitgamer330@gmail.com
