Cheap & Cheap Laptop CPU: Intel(R) Celeron(R) N4020 1.10GHz | Maximum: 2.7GHz GPU: Intel UHD Graphics 600 RAM: 4GB Storage: 64GB SSD
4 Questions View all
Laptop USB Port only works at a certain angle
I’ve got a laptop with 2 USB Ports, but one only works at a certain angle. Works fine when pressure is constantly applied, no rotation. Works when tilted down (from upper view). Works when USB is between plugged in & unplugged. Sometimes my mouse lights up, but it doesn’t work.
Add a comment
1 Answer
Most Helpful Answer
I have one that is intermittent also. I think it is the contacts inside the socket. They are a spring hump design. If you are careful, you may be able to lift them using a fine tweezer. They won’t need to come up much. Get the tweezer point just under the hump and lift it slightly. Do all 4.
Score 1
1 Comment:
Be sure to first disconnect the charger and the battery!
by
Add a comment
Add your answer
Albert Einstein will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 22
All Time: 536
