Why is no fuel getting in the cylinder an not starting
Is there any way any one has a manual for it
change the gas line and remove the carburetor. use carb cleaner and remove everything to pieces and blow the cleaner in every hole. the float bowl injector is the screw that holds the gas reservoir of the carb to the engine. this is usually the culprit and needs to be cleaned.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 18
All Time: 739
3 Comments
Hello snsjss
by Ethan
@walker34 your blower a Homelite backpack blower (bp250)? If not we need more info about what engine it has etc.
by oldturkey03
Plugged gas line, fuel filter, fuel valve or carburetor gummed up.
by bill
