Released by Nikon in January 2014, the Coolpix L830 is a compact digital camera designed to provide powerful zoom with simple operation.
22 Questions View all
Why It only turns on with the power supply?
Nikon coolpix L830 started to place messages , card can not be read., i turn it off them On and it worked.
Now the camera does not turn on with the batteries , I plug it to the power supply and that's how it works.
Add a comment
1 Answer
batteries can be bad enough that they appear to be fully charged in the charger but have such a high internal resistance that the terminal voltage under load won’t run anything. If u really want to test it u must put a load across your DVM probes and connect to the output terminals.
1 Comment:
How i do it? A have a DVM and i have try several testing. Batteries are new and the charge is ok.any other tips?
by
Add a comment
Add your answer
Angel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 76
