Why it is hang after pressing √(10) *10^13
How to unhang calculator
Since you can't interact with the calculator at all, start with removing its battery by following the guide I have added below. You can skip replacing the battery, just put the same battery back again.
This will force the calculator to turn off.
Casio FX-991ES Plus Battery Replacement
If it still freezes when you do that, redo the process of removing the battery and then do the following steps to factory reset the calculator.
When the calculator is on.
Step 1: Press SHIFT
and then 9
Step 2: Press 3
to select the "Reset All" option
Step 3: Press =
to confirm
Step 4: Press the AC
button
Hope it works after this! :D
Not fixed
My calculator is hang and it is not resetting .
And not pressing any button
@Abhinash Shah Ohh, okay! I have updated my answer, hopefully, it will help to remove the battery to force the calculator to turn off and then performing the reset process.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 13
All Time: 809
