The Galaxy Watch Active2 is a smartwatch from Samsung Electronics. Its model number is SM-R825, SM-R830, or SM-R835 and was released in August 2019. Repair your Samsung Galaxy Watch Active2 with these guides.
47 Questions View all
After replacing battery, Galaxy watch shuts off to "cool down"
I assume that there's a battery temperature sensor that did not get properly reconnected, but I can't find anything that would tell me where to look. The watch is fully charged. I can turn it on, but within 15 seconds, the screen says "Watch turned off to cool down", and then it shuts down.
Add a comment
1 Answer
Chosen Solution
Alright, I have a probable answer. I took the watch apart again, and the connector from Step 4 wasn't seated properly. 🤦
When I reassembled the watch the first time, I thought that maybe, since they lined up when I put the two halves back together, they would make a firm connection, but they did not. When I took the watch apart again to investigate, the connector was clearly not attached. I reattached it firmly, reassembled the watch, and powered it back on. The watch stays on now, so I'm pretty sure that was the issue.
1 Comment:
Hello Karl, was this fix long lasting for you ?
I have similar troubles and I also converge to the fact that this cool down situation seems to be linked with the quality of this connector (bad contact ?). It seems that when I fully disconnect this connector and let it disasaembled from the mother board, the cool down issue is disappearing (at least for the last 36 hours ...). I am thus losing the heart sensor function, but at least all other functions remain available ...
Rem. : on a first attempts, it didn't worked : I then reopened the watch to discover that the connector had ... reconnected (due to the tighness of the watch case in fact). So on a second attempt I put a small piece of tape on the connector to isolate it.
by
Add a comment
Add your answer
Karl Arp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 54
All Time: 1,244
